I have a host (a switch device), which provides temperature threshold values within its own SNMP tree (warning and critical values for different switch modules/components). I can correctly recieve these as items.
Can I create a discovery rule, where I would define a trigger execution which compares the current average temperature value (primary temp item) with the value of the threshold item (represented as a result) which would trigger the action?
Thx,
Miro.
Thx,
Miro.
