Downtime/maintenance individual triggers
  • quackduck
    • Feb 2025
    • 39
    Just setting up maintenance on a host is a hassle on its own. You have to specify not one but two time windows, which is redundant, really, since other monitoring software can do it while achieving exactly the same thing (but better) plus more in a more intuitive and concice UI.
    Anyhow. Now even worse is to set up maintenance for a single trigger. The only way is to set up maintenance on tags? And host-level tags on inherited triggers aren't permanent/reliable
    edit: I posted something else.. but the site posted the unfinished state of the text from 5-10 minutes ago. Or maybe it cuts off the rest of the text from the first emoticon included. Nice.
