zabbix behind nginx proxy manager, login works, but then 404 Not Found
  • mx738
    • Mar 2025
    i install a fresh zabbix on a Proxmox LXC Debian 12 and nginx.
    We have a NGINX proxy Manager for SSL Certificates
    When i access the zabbix by IP everything is working well.
    If i access by domain name, i see the Login screen, i'm able to login but then it shows:
    404 Not Found
    nginx/1.22.1
    On the nginx proxy i forward http IP-Address Port 8080
    Any idea?
  • Brambo
    • Jul 2023
    • 250
    I got it behind an NPM as well without any issues. Dashboard URL is similar to yours so doesn't look like a Zabbix server issue.
    In the NPM proxy host:
    I got Scheme: http
    Forward: my zabbix server ip.
    Forward port: http port
    Block common exploits, websockets support on
    SSL tab: Force SSL, HTTP/2 support on
    That should do the trick
