default user and pass of zabbix applianace
  • mthm
    • Apr 2017
    • 10
    Hello
    I installed zabbix appliance_3.2.3 and can access web successfully.
    but I cannot to access linux.
    What is default user and pass of linux zabbix appliance?
    Thanks.
  • jan.garaj
    • Jan 2010
    • 506
    appliance:zabbix -> https://www.zabbix.com/documentation...nual/appliance
    • mthm
      • Apr 2017
      • 10
      Thanks a lot.
      I read this doc, before this.
      I cannot access root user of system. I wanted change date, but I can change it, now by sudo command.
      Thanks.
      • mthm
        • Apr 2017
        • 10
        I'm sorry. I donot know English, well.
        I cannot see reply post after send it, immediately. I have a problem with time of web. I changed time zone on system correctly, but in web time is different.
        Please help me. Thanks.
        • Atsushi
          • Aug 2013
          • 2028
          Please read manual and set timezone for PHP.
          Frontend timezone is set to Europe/Riga (this can be modified in /etc/apache2/conf-available/zabbix.conf);
          • mthm
            • Apr 2017
            • 10
            Thanks a lot.
            • Feralo
              • Apr 2020
              Originally posted by jan.garaj
              I just downloaded the appliance qcow2 image this morning and the login credentials displayed in the documentation are not correct.
              How can I log into the VM?
              Thank you!
              • Feralo
                • Apr 2020
                Solved!
                Don't read old documentation (3.2) when downloading new software (4.4).
                • xbitro
                  • Dec 2023
                  Hi everyone.
                  Recently Im trying to install Zabbix Appliance 5.0.4 in QNAP VS3, but default credentials for console "appliance:zabbix" dont work. In fact nothing seems to work. "root:NOPASS"; "Admin:zabbix"; "Admin:Zabbix"; "Admin:NOPASS", etc... Has anything changed in this particular version ? NOTE: the login in VM Centos8 is "appliance login: "
