Host automatically get's Agents with multiple addresses
  • Fr4nk
    • Mar 2025
    we have installed a few hundred Zabbix agents with the parameter HostInterface, that it's listenign to the dns hostname and not the ip, cause of dhcp for the clients.
    the first line is coming after the installation.
    the other lines are coming automatically after some time. i guess it has something to do with dhcp.
    when i change the first line from 192.168.21.75 to 0.0.0.0 and remove the other agents all works fine.
    if i remove the othe ragents but keep the ip at first line, the entrys are coming again.
    can i install the zabbix agent msi with some parameter, that the client is registered at the server with 0.0.0.0 ?
    Thanks in advance
    Frank
Name:	Screenshot 2025-03-27 135618.png
  • Moob
    • Mar 2025
    • 31
    Regards
    • Moob
      • Mar 2025
      • 31
      Sorry, pressed to quickly on save You can add parameters via msiexec, see the link.
      Regards
