I use the zabbix appliance on Hyper-V. From version 3.2.3 to 3.2.4, I upgraded using the sudo apt-get upgrade command. Now that version 3.2.5 is already solving the triggers problem I've reported earlier, I'm unable to upgrade.
The sudo apt-get update + sudo apt-get upgrade can not find anything. Do you know how easy to upgrade?
Aleš
Aleš
