I am using the template for nutanix "Nutanix Cluster Prism Element by HTTP" that is on this page.
I added a trigger prototype of this type:
my host to which the template is connected is monitored via a remote active zabbix proxy. the versions are:
the master item is retrieved every minute. My problem is that the trigger is discovered after tens of minutes (even 30 minutes) and not a few seconds as I would expect since I set the ProxyConfigFrequency parameter to 5 seconds. note that if I restart the zabbix proxy the triggers are discovered immediately and i see this message on logs:
Also i do not see any error in zabbix proxy logs
ideas on how to solve? thanks
fapio
last(/Prism Central via API/nutanix.cluster.alert.state["{#ALERT.KEY}"])=1
zabbix server: 7.0.11 zabbix proxy: 7.0.2
received configuration data from server at datalen
fapio
