Item became not supported: Cannot execute script: RangeError: execution timeout
  • asherlab
    • Apr 2025
    Hi Team,
    We are facing an intermittent issue where some of our items are receiving this error:
    Intermittent means that it occur randomly like once or twice a day, which causes us to receive false alert as the nodata section of the trigger expression is getting triggered due to nodata received from the item. See image below where the timestamp for 11:29:09 and 11:30:09 are missing which causes the alert.
    Click image for larger version  Name:	Picture1.png Views:	0 Size:	51.6 KB ID:	501280
    Trigger:
    last(/aws-kube-prod-01-powercompany-cloud/service_preview-powercompany-cloud_service-usermanagement-backend-liveness.live)<>"{\"status\":\"UP\"}" or nodata(/aws-kube-prod-01-powercompany-cloud/service_preview-powercompany-cloud_service-usermanagement-backend-liveness.live,90s)=1
    Item:
    var url = "https://service_preview.powercompany.cloud/service-usermanagement-backend/actuator/health/liveness";
    var maxRetries = 3;
    var retryDelay = 5000;
    var attempt = 0;
    var result = null;
    function makeRequest() {
        try {
            var request = new HttpRequest();
            return request.get(url);
        } catch (error) {
            return error.message || error;
    while (attempt < maxRetries) {
        result = makeRequest();
        if (result && result.includes('{"status":"UP"')) {
            break;
        attempt++;
        if (attempt < maxRetries) {
            Zabbix.sleep(retryDelay);
    return result;
    Background:
    - We have numerous liveness/readiness check endpoints. Above one to name a few.
    - All of our the endpoint services (liveness/readiness) that we monitor are returning data in less than 1 second. As in superfast.
    To address the issue we have tried the following attempts but all are to no avail.
    1. Increased the timeout of the item script to 60. Before it was 3 seconds.
    2. Increased zabbix-server and zabbix-postgresql resource requests/limits.
    We know that zabbix-server and zabbix-postgresql are resource heavy especially if we are monitoring huge amount of data.
    For the server:
    resources:
    limits:
    cpu: '2'
    memory: 9Gi
    requests:
    cpu: '2'
    memory: 9Gi
    For the server:
    resources:
    limits:
    cpu: '2'
    memory: 9Gi
    requests:
    cpu: '2'
    memory: 9Gi
    Click image for larger version  Name:	image.png Views:	0 Size:	164.4 KB ID:	501284
    3. Modified some internals of zabbix processes such as STARTPOLLERS to acommodate more items.
    As we understand STARPOLLERS are responsible for allocating resource to items so that it can be able to fetched those intime. By default STARTPOLLERS are set to 5, however we have increased it to 35. Below shown Zabbix Processes:
    Click image for larger version  Name:	image.png Views:	0 Size:	223.2 KB ID:	501285
    Click image for larger version  Name:	image.png Views:	0 Size:	151.2 KB ID:	501286​​
    4. We also switched to used TimescaleDB. We have noticed performance improvement on the housekeeping process compared to regular postgres where housekeeping process reaches to 100%. But still we are getting the same issue mentioned in the title.
    Click image for larger version  Name:	image.png Views:	0 Size:	419.6 KB ID:	501287​
    5. We also increased the ingress-controller replica count, assuming that it could be network related. Our Istio ingress controller is not heavily utilized but we still decided to increased it to 3 replica. However doing so still doesn't work as the same issue still reoccurs intemittently.
    > We have noticed though that there are no request really made against our istio-ingressgateway. Which means the zabbix-server doesn't even made a GET against the service as we traced it in the istio logs as it appears to be missing. This led us to have all the actions above to ensure Zabbix has the best performance to process all of the items but to no avail.
    6. We even reduced the number of polling of Native Kubernetes alerts from 2 minutes to 1 minute to halve the number of VPS (Values per second) zabbix is processing. From 300 VPS down to 150 VPS. However doing so still doesn't work.
    Does anyone face a similar problem? We hope that we can find a fix for this as we are receiving false alert due to nodata issue.
    Here are the Zabbix components that we are using:
    - Zabbix-Web 7.0.3
    - Zabbix-Server 7.0.3
    - Zabbix Agent 7.0.3
    - Zabbix Pg16 with Timescaledb 2.15.3
    * We have deployed it inside a Kubernetes cluster version 1.30
    Will appreciate any help. Thank you!
  • asherlab
    • Apr 2025
    Here is the zabbix_server.conf
    # This is a configuration file for Zabbix server daemon
    # To get more information about Zabbix, visit https://www.zabbix.com
    ### Option: ListenPort
    # Listen port for trapper.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10051
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    LogType=console
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_server.pid
    ### Option: SocketDir
    # IPC socket directory.
    # Directory to store IPC sockets used by internal Zabbix services.
    # Mandatory: no
    # Default:
    # SocketDir=/tmp
    SocketDir=/tmp/
    ### NOTE: Support for Oracle DB is deprecated since Zabbix 7.0 and will be removed in future versions.
    ### Option: DBHost
    # Database host name.
    # If set to localhost, socket is used for MySQL.
    # If set to empty string, socket is used for PostgreSQL.
    # If set to empty string, the Net Service Name connection method is used to connect to Oracle database; also see
    # the TNS_ADMIN environment variable to specify the directory where the tnsnames.ora file is located.
    # Mandatory: no
    # Default:
    # DBHost=localhost
    DBHost=zabbix-postgresql
    ### Option: DBName
    # Database name.
    # If the Net Service Name connection method is used to connect to Oracle database, specify the service name from
    # the tnsnames.ora file or set to empty string; also see the TWO_TASK environment variable if DBName is set to
    # empty string.
    # Mandatory: yes
    # Default:
    # DBName=
    DBName=zabbix
    ### Option: DBSchema
    # Schema name. Used for PostgreSQL.
    # Mandatory: no
    # Default:
    # DBSchema=
    DBSchema=public
    ### Option: DBUser
    # Database user.
    # Mandatory: no
    # Default:
    # DBUser=
    DBUser=zabbix
    ### Option: DBPassword
    # Database password.
    # Comment this line if no password is used.
    # Mandatory: no
    # Default:
    # DBPassword=
    DBPassword=secret
    ### Option: DBSocket
    # Path to MySQL socket.
    # Mandatory: no
    # Default:
    # DBSocket=
    ### Option: DBPort
    # Database port when not using local socket.
    # If the Net Service Name connection method is used to connect to Oracle database, the port number from the
    # tnsnames.ora file will be used. The port number set here will be ignored.
    # Mandatory: no
    # Range: 1024-65535
    # Default:
    # DBPort=
    DBPort=5432
    ### Option: AllowUnsupportedDBVersions
    # Allow server to work with unsupported database versions.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowUnsupportedDBVersions=0
    ### Option: HistoryStorageURL
    # History storage HTTP[S] URL.
    # Mandatory: no
    # Default:
    # HistoryStorageURL=
    ### Option: HistoryStorageTypes
    # Comma separated list of value types to be sent to the history storage.
    # Mandatory: no
    # Default:
    # HistoryStorageTypes=uint,dbl,str,log,text
    ### Option: HistoryStorageDateIndex
    # Enable preprocessing of history values in history storage to store values in different indices based on date.
    # 0 - disable
    # 1 - enable
    # Mandatory: no
    # Default:
    # HistoryStorageDateIndex=0
    ### Option: ExportDir
    # Directory for real time export of events, history and trends in newline delimited JSON format.
    # If set, enables real time export.
    # Mandatory: no
    # Default:
    # ExportDir=
    ### Option: ExportFileSize
    # Maximum size per export file in bytes.
    # Only used for rotation if ExportDir is set.
    # Mandatory: no
    # Range: 1M-1G
    # Default:
    # ExportFileSize=1G
    ### Option: ExportType
    # List of comma delimited types of real time export - allows to control export entities by their
    # type (events, history, trends) individually.
    # Valid only if ExportDir is set.
    # Mandatory: no
    # Default:
    # ExportType=events,history,trends
    ############ ADVANCED PARAMETERS ################
    ### Option: StartPollers
    # Number of pre-forked instances of pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollers=5
    StartPollers=35
    ### Option: StartAgentPollers
    # Number of pre-forked instances of asynchronous Zabbix agent pollers. Also see MaxConcurrentChecksPerPoller.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartAgentPollers=1
    ### Option: StartHTTPAgentPollers
    # Number of pre-forked instances of asynchronous HTTP agent pollers. Also see MaxConcurrentChecksPerPoller.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPAgentPollers=1
    ### Option: StartSNMPPollers
    # Number of pre-forked instances of asynchronous SNMP pollers. Also see MaxConcurrentChecksPerPoller.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartSNMPPollers=1
    ### Option: MaxConcurrentChecksPerPoller
    # Maximum number of asynchronous checks that can be executed at once by each HTTP agent poller or agent poller.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxConcurrentChecksPerPoller=1000
    ### Option: StartIPMIPollers
    # Number of pre-forked instances of IPMI pollers.
    # The IPMI manager process is automatically started when at least one IPMI poller is started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartIPMIPollers=0
    ### Option: StartPreprocessors
    # Number of pre-started instances of preprocessing workers.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartPreprocessors=3
    StartPreprocessors=10
    ### Option: StartConnectors
    # Number of pre-forked instances of connector workers.
    # The connector manager process is automatically started when connector worker is started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartConnectors=0
    ### Option: StartPollersUnreachable
    # Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
    # At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
    # are started.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPollersUnreachable=1
    ### Option: StartHistoryPollers
    # Number of pre-forked instances of history pollers.
    # Only required for calculated checks.
    # A database connection is required for each history poller instance.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHistoryPollers=5
    ### Option: StartTrappers
    # Number of pre-forked instances of trappers.
    # Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
    # At least one trapper process must be running to display server availability and view queue
    # in the frontend.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartTrappers=5
    ### Option: StartPingers
    # Number of pre-forked instances of ICMP pingers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartPingers=1
    ### Option: StartDiscoverers
    # Number of pre-started instances of discovery workers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartDiscoverers=5
    ### Option: StartHTTPPollers
    # Number of pre-forked instances of HTTP pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartHTTPPollers=1
    ### Option: StartTimers
    # Number of pre-forked instances of timers.
    # Timers process maintenance periods.
    # Only the first timer process handles host maintenance updates. Problem suppression updates are shared
    # between all timers.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # StartTimers=1
    ### Option: StartEscalators
    # Number of pre-forked instances of escalators.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartEscalators=1
    ### Option: StartAlerters
    # Number of pre-forked instances of alerters.
    # Alerters send the notifications created by action operations.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartAlerters=3
    ### Option: JavaGateway
    # IP address (or hostname) of Zabbix Java gateway.
    # Only required if Java pollers are started.
    # Mandatory: no
    # Default:
    # JavaGateway=
    ### Option: JavaGatewayPort
    # Port that Zabbix Java gateway listens on.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # JavaGatewayPort=10052
    ### Option: StartJavaPollers
    # Number of pre-forked instances of Java pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartJavaPollers=0
    ### Option: StartVMwareCollectors
    # Number of pre-forked vmware collector instances.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartVMwareCollectors=0
    ### Option: VMwareFrequency
    # How often Zabbix will connect to VMware service to obtain a new data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwareFrequency=60
    ### Option: VMwarePerfFrequency
    # How often Zabbix will connect to VMware service to obtain performance data.
    # Mandatory: no
    # Range: 10-86400
    # Default:
    # VMwarePerfFrequency=60
    ### Option: VMwareCacheSize
    # Size of VMware cache, in bytes.
    # Shared memory size for storing VMware data.
    # Only used if VMware collectors are started.
    # Mandatory: no
    # Range: 256K-2G
    # Default:
    # VMwareCacheSize=8M
    ### Option: VMwareTimeout
    # Specifies how many seconds vmware collector waits for response from VMware service.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # VMwareTimeout=10
    ### Option: SNMPTrapperFile
    # Temporary file used for passing data from SNMP trap daemon to the server.
    # Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
    # Mandatory: no
    # Default:
    # SNMPTrapperFile=/tmp/zabbix_traps.tmp
    ### Option: StartSNMPTrapper
    # If 1, SNMP trapper process is started.
    # Mandatory: no
    # Range: 0-1
    # Default:
    # StartSNMPTrapper=0
    ### Option: ListenIP
    # List of comma delimited IP addresses that the trapper should listen on.
    # Trapper will listen on all network interfaces if this parameter is missing.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: HousekeepingFrequency
    # How often Zabbix will perform housekeeping procedure (in hours).
    # Housekeeping is removing outdated information from the database.
    # To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
    # hours of outdated information are deleted in one housekeeping cycle, for each item.
    # To lower load on server startup housekeeping is postponed for 30 minutes after server start.
    # With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
    # In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
    # period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
    # Mandatory: no
    # Range: 0-24
    # Default:
    # HousekeepingFrequency=1
    ### Option: MaxHousekeeperDelete
    # The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
    # [housekeeperid], [tablename], [field], [value].
    # No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
    # will be deleted per one task in one housekeeping cycle.
    # If set to 0 then no limit is used at all. In this case you must know what you are doing!
    # Mandatory: no
    # Range: 0-1000000
    # Default:
    # MaxHousekeeperDelete=5000
    ### Option: CacheSize
    # Size of configuration cache, in bytes.
    # Shared memory size for storing host, item and trigger data.
    # Mandatory: no
    # Range: 128K-64G
    # Default:
    # CacheSize=32M
    CacheSize=200M
    ### Option: CacheUpdateFrequency
    # How often Zabbix will perform update of configuration cache, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # CacheUpdateFrequency=10
    ### Option: StartDBSyncers
    # Number of pre-forked instances of DB Syncers.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartDBSyncers=4
    ### Option: HistoryCacheSize
    # Size of history cache, in bytes.
    # Shared memory size for storing history data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryCacheSize=16M
    ### Option: HistoryIndexCacheSize
    # Size of history index cache, in bytes.
    # Shared memory size for indexing history cache.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # HistoryIndexCacheSize=4M
    ### Option: TrendCacheSize
    # Size of trend write cache, in bytes.
    # Shared memory size for storing trends data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # TrendCacheSize=4M
    ### Option: TrendFunctionCacheSize
    # Size of trend function cache, in bytes.
    # Shared memory size for caching calculated trend function data.
    # Mandatory: no
    # Range: 128K-2G
    # Default:
    # TrendFunctionCacheSize=4M
    ### Option: ValueCacheSize
    # Size of history value cache, in bytes.
    # Shared memory size for caching item history data requests.
    # Setting to 0 disables value cache.
    # Mandatory: no
    # Range: 0,128K-64G
    # Default:
    # ValueCacheSize=8M
    ValueCacheSize=200M
    ### Option: Timeout
    # Specifies timeout for communications (in seconds).
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: TrapperTimeout
    # Specifies how many seconds trapper may spend processing new data.
    # Mandatory: no
    # Range: 1-300
    # Default:
    # TrapperTimeout=300
    ### Option: UnreachablePeriod
    # After how many seconds of unreachability treat a host as unavailable.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachablePeriod=45
    ### Option: UnavailableDelay
    # How often host is checked for availability during the unavailability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnavailableDelay=60
    ### Option: UnreachableDelay
    # How often host is checked for availability during the unreachability period, in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # UnreachableDelay=15
    ### Option: AlertScriptsPath
    # Full path to location of custom alert scripts.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_server --help".
    # Mandatory: no
    # Default:
    # AlertScriptsPath=${datadir}/zabbix/alertscripts
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ### Option: ExternalScripts
    # Full path to location of external scripts.
    # Mandatory: no
    # Default:
    # ExternalScripts=${datadir}/zabbix/externalscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    ### Option: FpingLocation
    # Location of fping.
    # Make sure that fping binary has root ownership and SUID flag set.
    # Mandatory: no
    # Default:
    # FpingLocation=/usr/sbin/fping
    FpingLocation=/usr/bin/fping
    ### Option: Fping6Location
    # Location of fping6.
    # Make sure that fping6 binary has root ownership and SUID flag set.
    # Make empty if your fping utility is capable to process IPv6 addresses.
    # Mandatory: no
    # Default:
    # Fping6Location=/usr/sbin/fping6
    ### Option: SSHKeyLocation
    # Location of public and private keys for SSH checks and actions.
    # Mandatory: no
    # Default:
    # SSHKeyLocation=
    SSHKeyLocation=/var/lib/zabbix/ssh_keys
    ### Option: LogSlowQueries
    # How long a database query may take before being logged (in milliseconds).
    # Only works if DebugLevel set to 3, 4 or 5.
    # 0 - don't log slow queries.
    # Mandatory: no
    # Range: 1-3600000
    # Default:
    # LogSlowQueries=0
    ### Option: TmpDir
    # Temporary directory.
    # Mandatory: no
    # Default:
    # TmpDir=/tmp
    ### Option: StartProxyPollers
    # Number of pre-forked instances of pollers for passive proxies.
    # Mandatory: no
    # Range: 0-250
    # Default:
    # StartProxyPollers=1
    ### Option: ProxyConfigFrequency
    # How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
    # This parameter is used only for proxies in the passive mode.
    # Mandatory: no
    # Range: 1-3600*24*7
    # Default:
    # ProxyConfigFrequency=10
    ### Option: ProxyDataFrequency
    # How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ProxyDataFrequency=1
    ### Option: StartLLDProcessors
    # Number of pre-forked instances of low level discovery processors.
    # Mandatory: no
    # Range: 1-100
    # Default:
    # StartLLDProcessors=2
    ### Option: AllowRoot
    # Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    User=zabbix
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    # Include=/usr/local/etc/zabbix_server.general.conf
    # Include=/usr/local/etc/zabbix_server.conf.d/
    # Include=/usr/local/etc/zabbix_server.conf.d/*.conf
    ### Option: SSLCertLocation
    # Location of SSL client certificates.
    # This parameter is used in web monitoring and for communication with Vault.
    # Mandatory: no
    # Default:
    # SSLCertLocation=${datadir}/zabbix/ssl/certs
    SSLCertLocation=/var/lib/zabbix/ssl/certs/
    ### Option: SSLKeyLocation
    # Location of private keys for SSL client certificates.
    # Mandatory: no
    # Default:
    # SSLKeyLocation=${datadir}/zabbix/ssl/keys
    SSLKeyLocation=/var/lib/zabbix/ssl/keys/
    ### Option: SSLCALocation
    # Override the location of certificate authority (CA) files for SSL server certificate verification.
    # If not set, system-wide directory will be used.
    # This parameter is used in web monitoring, SMTP authentication, HTTP agent items and for communication with Vault.
    # Mandatory: no
    # Default:
    # SSLCALocation=
    SSLCALocation=/var/lib/zabbix/ssl/ssl_ca/
    ### Option: StatsAllowedIP
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of external Zabbix instances.
    # Stats request will be accepted only from the addresses listed here. If this parameter is not set no stats requests
    # will be accepted.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: StatsAllowedIP=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: no
    # Default:
    # StatsAllowedIP=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of server modules.
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    LoadModulePath=/var/lib/zabbix/modules/
    # Module to load at server startup. Modules are used to extend functionality of the server.
    # Formats:
    # LoadModule=<module.so>
    # LoadModule=<path/module.so>
    # LoadModule=</abs_path/module.so>
    # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
    # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSCertFile
    # Full pathname of a file containing the server certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the server private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    ### Option: DBTLSConnect
    # Setting this option enforces to use TLS connection to database.
    # required - connect using TLS
    # verify_ca - connect using TLS and verify certificate
    # verify_full - connect using TLS, verify certificate and verify that database identity specified by DBHost
    # matches its certificate
    # On MySQL starting from 5.7.11 and PostgreSQL following values are supported: "required", "verify_ca" and
    # "verify_full".
    # On MariaDB starting from version 10.2.6 "required" and "verify_full" values are supported.
    # Default is not to set any option and behavior depends on database configuration
    # Mandatory: no
    # Default:
    # DBTLSConnect=
    ### Option: DBTLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for database certificate verification.
    # Supported only for MySQL and PostgreSQL
    # Mandatory: no
    # (yes, if DBTLSConnect set to one of: verify_ca, verify_full)
    # Default:
    # DBTLSCAFile=
    ### Option: DBTLSCertFile
    # Full pathname of file containing Zabbix server certificate for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSCertFile=
    ### Option: DBTLSKeyFile
    # Full pathname of file containing the private key for authenticating to database.
    # Mandatory: no
    # Default:
    # DBTLSKeyFile=
    ### Option: DBTLSCipher
    # The list of encryption ciphers that Zabbix server permits for TLS protocols up through TLSv1.2
    # Mandatory no
    # Default:
    # DBTLSCipher=
    ### Option: DBTLSCipher13
    # The list of encryption ciphersuites that Zabbix server permits for TLSv1.3 protocol
    # Supported only for MySQL, starting from version 8.0.16
    # Mandatory no
    # Default:
    # DBTLSCipher13=
    ### Option: Vault
    # Specifies vault:
    # HashiCorp - HashiCorp KV Secrets Engine - Version 2
    # CyberArk - CyberArk Central Credential Provider
    # Mandatory: no
    # Default:
    # Vault=HashiCorp
    ### Option: VaultToken
    # Vault authentication token that should have been generated exclusively for Zabbix server with read only permission
    # to paths specified in Vault macros and read only permission to path specified in optional VaultDBPath
    # configuration parameter.
    # It is an error if VaultToken and VAULT_TOKEN environment variable are defined at the same time.
    # Mandatory: no
    # (yes, if Vault is explicitly set to HashiCorp)
    # Default:
    # VaultToken=
    ### Option: VaultURL
    # Vault server HTTP[S] URL. System-wide CA certificates directory will be used if SSLCALocation is not specified.
    # Mandatory: no
    # Default:
    # VaultURL=https://127.0.0.1:8200
    ### Option: VaultPrefix
    # Custom prefix for Vault path or query depending on the Vault.
    # Most suitable defaults will be used if not specified.
    # Note that 'data' is automatically appended after mountpoint for HashiCorp if VaultPrefix is not specified.
    # Example prefix for HashiCorp:
    # /v1/secret/data/
    # Example prefix for CyberArk:
    # /AIMWebService/api/Accounts?
    # Mandatory: no
    # Default:
    # VaultPrefix=
    ### Option: VaultDBPath
    # Vault path or query depending on the Vault from where credentials for database will be retrieved by keys.
    # Keys used for HashiCorp are 'password' and 'username'.
    # Example path:
    # secret/zabbix/database
    # Keys used for CyberArk are 'Content' and 'UserName'.
    # Example query:
    # AppID=zabbix_server&Query=Safe=passwordSafe;Object=zabbix_server_database
    # This option can only be used if DBUser and DBPassword are not specified.
    # Mandatory: no
    # Default:
    # VaultDBPath=
    ### Option: VaultTLSCertFile
    # Name of the SSL certificate file used for client authentication. The certificate file must be in PEM1 format.
    # If the certificate file contains also the private key, leave the SSL key file field empty. The directory
    # containing this file is specified by configuration parameter SSLCertLocation.
    # Mandatory: no
    # Default:
    # VaultTLSCertFile=
    ### Option: VaultTLSKeyFile
    # Name of the SSL private key file used for client authentication. The private key file must be in PEM1 format.
    # The directory containing this file is specified by configuration parameter SSLKeyLocation.
    # Mandatory: no
    # Default:
    # VaultTLSKeyFile=
    ### Option: StartReportWriters
    # Number of pre-forked report writer instances.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartReportWriters=0
    StartReportWriters=1
    ### Option: WebServiceURL
    # URL to Zabbix web service, used to perform web related tasks.
    # Example: http://localhost:10053/report
    # Mandatory: no
    # Default:
    # WebServiceURL=
    WebServiceURL=http://zabbix-zabbix-webservice:10053/report
    ### Option: ServiceManagerSyncFrequency
    # How often Zabbix will synchronize configuration of a service manager (in seconds).
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ServiceManagerSyncFrequency=60
    ### Option: ProblemHousekeepingFrequency
    # How often Zabbix will delete problems for deleted triggers (in seconds).
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # ProblemHousekeepingFrequency=60
    ## Option: StartODBCPollers
    # Number of pre-forked ODBC poller instances.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartODBCPollers=1
    ### Option: EnableGlobalScripts
    # Enable global scripts on Zabbix server.
    # 0 - disable
    # 1 - enable
    # Mandatory: no
    # Default:
    # EnableGlobalScripts=1
    # Option: AllowSoftwareUpdateCheck
    # Allow Zabbix UI to receive information about software updates from zabbix.com
    # 0 - disable software update checks
    # 1 - enable software update checks
    # Mandatory: no
    # Default:
    # AllowSoftwareUpdateCheck=1
    ### Option: SMSDevices
    # List of comma delimited modem files allowed to use Zabbix server
    # SMS sending not possible if this parameter is not set
    # Example: SMSDevices=/dev/ttyUSB0,/dev/ttyUSB1
    # Mandatory: no
    # Default:
    # SMSDevices=
    ####### For advanced users - TCP-related fine-tuning parameters #######
    ## Option: ListenBacklog
    # The maximum number of pending connections in the queue. This parameter is passed to
    # listen() function as argument 'backlog' (see "man listen").
    # Mandatory: no
    # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
    # Default: SOMAXCONN (hard-coded constant, depends on system)
    # ListenBacklog=
    ####### High availability cluster parameters #######
    ## Option: HANodeName
    # The high availability cluster node name.
    # When empty, server is working in standalone mode; a node with empty name is registered with address for the frontend to connect to.
    # Mandatory: no
    # Default:
    # HANodeName=
    HANodeName=zabbix-zabbix-server-8647dfb7f-jmlks
    ## Option: NodeAddress
    # IP or hostname with optional port to specify how frontend should connect to the server.
    # Format: <address>[:<port>]
    # If IP or hostname is not set, then ListenIP value will be used. In case ListenIP is not set, localhost will be used.
    # If port is not set, then ListenPort value will be used. In case ListenPort is not set, 10051 will be used.
    # This option can be overridden by address specified in frontend configuration.
    # Mandatory: no
    # Default:
    # NodeAddress=localhost:10051
    NodeAddress=10.16.79.137
    ####### Browser monitoring #######
    ### Option: WebDriverURL
    # WebDriver interface HTTP[S] URL. For example http://localhost:4444 used with Selenium WebDriver standalone server.
    # Mandatory: no
    # Default:
    # WebDriverURL=
    ### Option: StartBrowserPollers
    # Number of pre-forked instances of browser item pollers.
    # Mandatory: no
    # Range: 0-1000
    # Default:
    # StartBrowserPollers=1
      From the initial description everything works exactly, as you have designed it... either status is not UP OR there is no data... I would not say, something is wrong here, if you designed, that trigger exactly like that...
      You are concentrating on the issue that your zabbix is at fault... Have you ever thought that maybe that particular endpoint is to blame?
      How is that nvps going down if you start polling twice as much as before?
      • asherlab
        • Apr 2025
        Hello cyber,
        Correcting our statement it should be:
        6. We even reduced the number of polling of Native Kubernetes alerts from 1 minute to 2 minute to halve the number of VPS (Values per second) zabbix is processing. From 300 VPS down to 150 VPS. However doing so still doesn't work.
        • asherlab
          • Apr 2025
          Hello team,
          We have investigated it further and introduced a logging mechanism in the item script to see if Zabbix really is executing it.
          The lines we introduced in the item are, for us to be able to see the logs and check if Zabbix does really executes it and making an attempt to get a value of an item.
          HTML Code:
              Zabbix.log(3, "[" + getTimestamp() + "] Initiating request for " + url);
              Zabbix.log(3, "[" + getTimestamp() + "] Request completed for " + url + ".");
          It happens two times
          - Take note that each of the event below are extracted on the same timerange.
          TLDR: Zabbix did not even try to make an attempt to execute the item script.
          FIRST EXAMPLE:
          - 301:20250408:101331.945 item "my-item-liveness.live" became not supported: Cannot execute script: RangeError: execution timeout
          Click image for larger version  Name:	Screenshot 2025-04-16 at 8.55.42 PM.png Views:	0 Size:	91.5 KB ID:	501920
          - Of course the above event cause us to get alerted and induced a nodata alert.
          - Checking logs of Zabbix-server if its really made the request using the added lines we have above, it seems it did not really made any request at all.
          Click image for larger version  Name:	Screenshot 2025-04-16 at 8.59.19 PM.png Views:	0 Size:	121.4 KB ID:	501921Click image for larger version  Name:	Screenshot 2025-04-16 at 9.01.24 PM.png Views:	0 Size:	113.6 KB ID:	501923
          SECOND EXAMPLE:
          Click image for larger version  Name:	Screenshot 2025-04-16 at 9.11.54 PM.png Views:	4 Size:	88.6 KB ID:	501926
          Click image for larger version  Name:	Screenshot 2025-04-16 at 9.13.02 PM.png Views:	4 Size:	130.8 KB ID:	501927
          We suspect that Zabbix is the issue here, as it is unable to execute the item script on these two instances. We have already performed the recommended performance tuning steps as mentioned above.
          Does anyone have any idea what might be preventing Zabbix from executing the item script on these instances?
          Thank you for your support, team.
          • asherlab
            • Apr 2025
            SECOND EXAMPLE:
            Continuation of above example:
            Click image for larger version  Name:	Screenshot 2025-04-16 at 9.14.56 PM.png Views:	0 Size:	132.7 KB ID:	501930
            Below is the Zabbix performance as well
            Click image for larger version  Name:	image.png Views:	0 Size:	172.8 KB ID:	501966Click image for larger version  Name:	image.png Views:	0 Size:	299.1 KB ID:	501967
            Click image for larger version  Name:	image.png Views:	0 Size:	75.8 KB ID:	501968
            cc: @3113-cyber​
            • asherlab
              • Apr 2025
              What's interesting thing as well is Zabbix did not even execute the script but throw an error saying it become unsupported. It seems along the way it is able to recognize the item but not really executes it...
              • asherlab
                • Apr 2025
                Hello team, is there someone here experiencing the same issue?
                • asherlab
                  • Apr 2025
                  Just following up to say we're still experiencing the issue, and after extensive troubleshooting, it seems to be tied to Zabbix—any help or insight from the team or community would be greatly appreciated.
