Hi Zabbix community,
We have installed Zabbix and we have configured our Zabbix to monitoring different System paramenter. It is working fine with Groups, Trigger and differentes Keys.
The question is: How can I know how a Zabbix expression Works?
For example the sintax is : "{<server>:<key>.<function>(<parameter>)}
<operator><constant>".......... ok then you have for test the CPU the next expression : {www.zabbix.com:system.cpu.load[all,avg1].last()}>5
This is great,,,,but this expression should use Linux commands to check the cpu, is not it? How can I know how this expression works? Which Linux Command execute to know the status of the CPU?
THanks in advance
THanks in advance
