Zabbix-Grafana issues
  • onallion
    • Mar 2016
    • 131
    Hey guys, I'm having two separate issues with Zabbix Grafana.
    Zabbix 3.2 and Grafana latest version.
    1. Repeat row - I am unable to use this feature. When I go into "row options" there's no option to select repeat row. I know this feature is supposed to work because it does in the grafana-zabbix demo, but even there I don't see that option. Any advice?
    2. This is a possible bug. I'm using the repeat panel function to automatically create disk space graphs for each disk in the host. For some reason, Grafana also sees disk drives that do not exist on the host and creates empty panels.
    My query is:
    $group.*.Filesystems.*
    Regex filter is:
    /Total disk space on (.*)/
    The values I'm getting don't match the actual host, so for example if it only has a C:\ drive, Grafana sees C:\,F:\,Q:\...
    Would appreciate any help.
    Thanks!
    EDIT: Just solved the first issue, doh. Second issue still remains, though...
  • Semiadmin
    • Oct 2014
    • 1625
    Hi, onallion.
    Is there $host variable in your Templating ?
    May be, query'd
    $group.$host.Filesystems./Total disk space on (.*)/
    • onallion
      • Mar 2016
      • 131
      That was it. I stupidly used $group.* instead of $group.$host.
      Thank you so much!
