Cycling between maps on a single monitor
  • mol64
    • Apr 2025
    I'm currently using PRTG to monitor various devices, Switches, AP's, printers etc. Each of these items has its own map. We have one large display that cycles between these maps automatically. Showing each for about 10 seconds.
    We're hoping to switch to Zabbix and was wanting to create something similar. Is this possible?
  • Brambo
    • Jul 2023
    • 250
    Maybe to simple of a thought, but did you add the map on a dashboard?
    Then create multiple pages and let zabbix scroll through them.
    Additional tip. Make a generic problem field overview on all pages which shows problem of all maps so you don't miss anything of you have a lot of them.
    • mol64
      • Apr 2025
      Brilliant. I'm still learning and didn't know the dashboards did that. Works very well for me. Thanks you
