Change trigger severity after x days
  • ServicedeskITS
    • Jun 2016
    I am wondering if the following is possible in Zabbix and if it is possible....how
    We have multiple triggers ofcourse for our hosts and 1 of them is disk space check.
    As of now it checks if the server has less then 10% AND less then 10GB and the severity is Warning.
    What i would like is that after x days the severity changes to High.
    Is that possible??
  • Luiz Antonio Oliveira
    • Feb 2007
    • 49
    Create another trigger in another severity and make dependence
    or use .last(xd) and passs {TRIGGER.ID} in script with trigger.update and change your severity
