contains not working as expected
  • tlkhorses
    • Apr 2025
    • 10
    Running version 7.2.4. It looks like Alert>Discovery Actions using received value contains with service type SNMP isn't working as I thought it should. I'm trying to use it to link a template according to the type of device it is. So if I set Received value contains Mimosa it doesn't work and falls through the the generic catch all action of Network Generic Device by SNMP. If I use or in the action and list out each possible name it may find, the action then works. Same for other types of hardware such as RouterOS. I would have to list out each type of mikrotik using or. Using a snmp get on the ORI shows something like SNMPv2-MIB::sysDescr.0 = STRING: RouterOS RB4011iGS+. I would think that "contains" would catch RouterOS in that and apply the action.
    What am I missing or is this a bug?
