How to rename dashboard name after we create dashboard?
  • kronicklez
    • Mar 2025
    • 54
    Hi all,
    First of all i'm using version 7.4.0alpha1. May i know how to rename dashboard after we create it? I'm not see the option of rename the dashboard even after i choose dashboard and select "edit".
    Thanks and appreciate any feedback
  • bbonno
    • Apr 2025
    • 24
    Renaming is easy if you can find the button. Its right here:
    When editing your dashboard, click the cog.
    • mrnobody
      • Oct 2024
      • 61
      Originally posted by kronicklez
      Hi all,
      First click on Edit, and after it an Gear icon will appear, click on it and there you are, just change name (i agree that it could be less hidden ;o)
      • kronicklez
        • Mar 2025
        • 54
        Hi bro,
        Noted. Thanks for your help.
