7.2 Installation disk space requirements
  • marianogedisman
    • Oct 2021
    • 78
    Grüezi! How much disk space does Zabbix 7.2 take without the DB? I've read https://www.zabbix.com/documentation...n/requirementsbut this only speaks of DB size, not installation. I'm really space constrained so I'd really like to have a rough estimate or at least what attributes/aspects to pay attention when calculating disk space.
    Thanks in avance!
  • Answer selected by marianogedisman at 11-04-2025, 16:23.
    cyber
    • 5002
    Server itself requires very little room. Server binaries (7M) and log and config files.. If you have webserver also there.. I just looked, for v7 the web files take ~45M... I guess logs take more space, than the thing itself.. I guess you can find that gig or 2 ....
    • Moob
      • Mar 2025
      • 31
      Not sure. I have my Zabbix 7.0 on a VirtualBox VM with a 15Gbyte disk with 3,4Gbyte to spare. But I only save a history for 31d maximum.
      Regards
      • marianogedisman
        • Oct 2021
        • 78
        Regards
        Thanks for your input! But unfortunately this is not my case, my DB is on another server, I just need to know how much space should I calculate for the installation.
          • 5002
          • marianogedisman
            • Oct 2021
            • 78
            Thank you so much! This is exactly what I needed. I will follow your advice. Thanks again and happy weekend, cyber!
