HTTP POST/GET parameters to zabbix?
  • tarmogr
    • Apr 2017
    Hi
    I just installed zabbix, but I cant find a way to cature HTTP messages and store them as data in zabbix.
    I have a GSM module periodically sending HTTP GET messages to zabbix address, is it possible to capture the parameters from these messages?
    The IP address of GSM module is not static so the message itself has to identify the host.
    Can it be done with zabbix?
  • Luiz Antonio Oliveira
    • Feb 2007
    • 49
    You can read the log, get the data and send via sender to zabbix
    • tarmogr
      • Apr 2017
      EDIT: sender is the way to go, thanks.
      Now I just need to figure out a script to get those URL-s parsed to actual items and host names and use the sender command
