agent.ping.nodata() not working anymore?
  • akemper
    • Mar 2016
    • 10
    my server with Zabbix 3.2.5 does active monitoring of an attached Raspberry with OSMC and installed agent 2.2.7. Everything appears to be fine, that is when temporarily disconnecting the Raspi I can see this in the server log:
    temporarily disabling Zabbix agent checks on host "osmc": host unavailable
    enabling Zabbix agent checks on host "osmc": host became available
    Unfortunately the configured trigger {osmc:agent.ping.nodata(2m)}=1 doesn't anymore raise an event, which I guess has happened during update to 3.2.5 (or even earlier).
    Any idea what is wrong there or does the expression not work anymore like this?
    Thx,
    Andreas
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Thx,
    Andreas
    Hello!
    It looks like a bug:
    • akemper
      • Mar 2016
      • 10
      Fixed it successfully by following the guide on https://www.zabbix.org/wiki/Docs/howto/rebuild_debs including the provided patch. Thanks a lot, while initially I didn't really expect this to be a bug.
