Database versions don't match.
  • mshteyn
    • Apr 2025
    After upgrading from 6.4.3 to 7.2, I encounter an issue when trying to access the web interface. The following error appears.
    I'm using PostgreSQL and Nginx on Ubuntu 22.04. How can I resolve this?
  • mrnobody
    • Oct 2024
    • 61
    Need to upgrade database too.
      • 5002
      So how did your upgrade go? No issues ? Nothing strange in server log?
      • mshteyn
        • Apr 2025
        Nothing weird, all services ugraded and restarted normally and then the version thing popped up.
          • 5002
          If you server started up ok and did all the upgrade tasks, then this should not appear... Do you see all the "performing upgrade" lines in server log?
          • mshteyn
            • Apr 2025
            By that point i already fixed it - had to manually upgrade timescaledb for it to work.
