hi,
I did some searching but nothing seems to be working
we are switching to azure smtp which uses ssl on port 587 but i allways get the error wrong ssl version ... has somebody got this working and has a good step by step guide for this?
Thanks in advance, i am using zabbix version 6 but have also version 7 installed and that gives me the same error. My credentials are working fine because i tested it on windows programs and that works perfectly. My guess is i need to add some stuff to the zabbix config file? But what exactly?
Thanks in advance
Thanks in advance
