winget is not recognized
  • Blackdragon
    • Jan 2025
    • 47
    I'm creating a new item for Windows Server to check app updates. The code works perfectly in PowerShell, but it is not recognized in Zabbix
    winget : The term 'winget' is not recognized as the name of a cmdlet, function, script file, or operable program.
    Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
    At C:\path\Winget\ApplicationUpdates.ps1:2 char:12
    + $updates = winget upgrade
    + CategoryInfo : ObjectNotFound: (winget:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
    1
    How to fix this?
  • Blackdragon
    • Jan 2025
    • 47
    anyone have faced the same issue ?
    • bbonno
      • Apr 2025
      • 24
      This sounds like you have to preface your command with 'powershell.exe'.
      I don't quite remember which shell Zabbix uses by default, but that error reads like it the 'wrong' one for you. Instead of running Winget directly you should be able to start powershell, and have that run Winget.
