How to use zabbix in a basic server
  • isaas_jooj
    • Apr 2025
    Hello, i was assigned to monitor some servers using zabbix (VEEAM,IBM TSM, tapes usage, disks usage).
    even though i installed the client on my computer, i cant find anywhere how do i access the zabbix web monitor, im really struggling with the basics and im wondering if someone could help me in this journey.
    at the moment just create a server to monitor my own pc would be a great start.
  • avbxl
    • Jul 2024
    • 9
    First of all, you need more than a client. You need to set up a Zabbix server (there is extensive documentation on this: https://www.zabbix.com/download). Then you will need to install the Zabbix agent on the devices you want to monitor, or enable SNMP or IPMI monitoring. What exactly are you struggling with?
    • DoItAgainSteelyDan
      • Mar 2025
      • 21
      I recommend watching Dmitry Lamberts videos. https://www.youtube.com/channel/UCUQ...CjwQZQGznTkvrQ
