How to use vmware.vm.discovery with javascript preprocessing?
  • jhermsen
    • Apr 2025
    Can someone guide me on how I can use Javascript preprocessing with vmware.vm.discovery returned JSON?
    Also is there some schema definition of the returned json to use here?
    John
  • Answer selected by jhermsen at 06-05-2025, 14:45.
    cyber
    • 4993
    By writing your own JS script and using it...:P
    for vmware monitoring, there is a whole chapter in docs.. https://www.zabbix.com/documentation.../vm_monitoring keys, fields, examples..
    (yes, answer is as vague as the question)
      • 4993
      • jhermsen
        • Apr 2025
        Thank you, found some example using Zabbix.Log method and was able to output the json structure.
        So managed to figure it out using parts of the examples.
