using proxy in clustered environment
  • hakanozanlagan
    • Nov 2021
    • 35
    I have a Zabbix cluster server with 2 nodes. I need to set up a Zabbix proxy for this environment. However, Zabbix proxy does not allow the use of two IP addresses in the "Server=" definition and we can only use one IP address.
    I tried to do it with a load balancer. However, Zabbix cluster is running simultaneously with port 1051 open on both nodes and there is no way for the load balancer to understand which node is active.
    Is there a way to use a Zabbix proxy in a clustered environment?​
  • Moob
    • Mar 2025
    • 31
    What if you use 2 FQDN's with the same name but with different IP address, one for each of your nodes, and use that as the Server address in your proxy configuration ?
    Regards
    • psargent
      • Apr 2025
      Yes. You can have 2 IP addresses in the proxy conf. The separator is a semi colon.
      Server=address colon port;address2 colon port of Zabbix server
      • hakanozanlagan
        • Nov 2021
        • 35
        I tried below configs Proxy server is failed to start. it is running in agent conf but proxy is not supporting multiple server config.
        Server=192.168.88.100:10051,192.168.88.101:10051
        or
        Server=192.168.88.100,192.168.88.101
        • hakanozanlagan
          • Nov 2021
          • 35
          I solved problem with workaround.
          # add cluster status in "/usr/share/zabbix/clusterstatus.txt" file on both nodes via cron. (0 or 1)
          * * * * * zabbix_server -R ha_status |grep -c "Last Access" > /usr/share/zabbix/clusterstatus.txt
          #check server status and take action on proxy side.
          * * * * * /etc/zabbix/scripts/proxycheck.sh
          cat proxycheck.sh
          #!/bin/bash
          proxyActiveIp=$(grep "^Server=" /etc/zabbix/zabbix_proxy.conf |awk -F"=" '{print $2}')
          zbxsrv01status=$(curl -sk https://zbxsrv01.eduenv.com/clusterstatus.txt)
          zbxsrv02status=$(curl -sk https://zbxsrv02.eduenv.com/clusterstatus.txt)
          #check for nodes (192.168.88.100,192.168.88.101)
          if [ $zbxsrv01status == 1 ] && [ $proxyActiveIp != "192.168.88.100" ]
          then
          sed -i 's/^Server=192\.168\.88\.101$/Server=192.168.88.100/' /etc/zabbix/zabbix_proxy.conf
          systemctl restart zabbix-proxy
          elif [ $zbxsrv02status == 1 ] && [ $proxyActiveIp != "192.168.88.101" ]
          then
          sed -i 's/^Server=192\.168\.88\.100$/Server=192.168.88.101/' /etc/zabbix/zabbix_proxy.conf
          fi
          • psargent
            • Apr 2025
            The separator in the proxy config needs to be a semi colon.
            Server=192.168.88.100:10051;192.168.88.101:10051
            or
            Server=192.168.88.100;192.168.88.101​
            • hakanozanlagan
              • Nov 2021
              • 35
              or
              I didn't pay attention to the comment and just looked at the line below and saw the semicolon as a comma. It worked when I used a semicolon, thanks
