Template for Eaton 5px UPS
  • itdweeb99
    • Apr 2025
    Hi, I'm trying to find a template for an Eaton 5PX1500 UPS. I did find a 9PX template in the templates community but if I download it and then go to templates and try to import it, I get an error about not being able to parse line 7. Any feedback would be appreciated. Below is a link to the template I found. I don't really even know if this template will work for a 5PX but the user does say that the template will work with other models. I'm running Zabbix 7.2.
    community-templates/Power_(UPS)/Eaton/template_eaton_9px_6000i_ups/6.0 at main · zabbix/community-templates · GitHub
  • Answer selected by itdweeb99 at 09-05-2025, 19:58.
    Brambo
    • Jul 2023
    • 248
    Well first it's for zabbix 6 so any version lower than that it would import. So 7.2 should be fine.
    and line 7 is using group ups but since 6.4 (maybe even 6.2) template_Groups is a new things and I expect that is the reason.
    Looking at an export of a 7.x template it starts with:
    zabbix_export:
      version: '7.0'
      template_groups:
        - uuid:
          name:
    And if you look at the template it's different, you could try to change that part to try to make it work.
    Or just export a template from your instance and look for those kind of differences.
    • Brambo
      • Jul 2023
      • 248
      zabbix_export:
        version: '7.0'
        template_groups:
          - uuid:
            name:
