Free space in trigger
  • Moucha
    • May 2025
    We need create trigger for low free space on disk, but we need absolutely number. For example, we need trigger for Free space on disk is low then 3GB.
    How I create this trigger if I know Total space and Used space?
    I know, Its possible use Zabbix agent, but we don't want to install any agents on the servers.
    Thank you for answers.
  • stadmin
    • Jan 2025
    Hi Moucha,
    Could you elaborate your usecase. If you are not using the Zabbix agent, how do you get the data about disk usage into Zabbix?
    • Moucha
      • May 2025
      I say, i know Total space and Used space from SNMP, but, how i create trigger? (Free space = Total space - Used Space) < 3GB, for example.
        • 4985
        https://www.zabbix.com/documentation...ers/expression Example 14... How hard can it be?
