Check Point CPU monitoring
  • dr.grinspoon
    • May 2025
    hello, I am writing to you because I need your help, until today I was able to monitor the cpu of the firewall checkpoints, now due to a kernel change I have to use a new SNMP OID TREE and I can't build the discovery rule, item prototype and trigger to automatically detect all the cpu's present and give me the usage values for each of them.
    SNMP OID:1.3.6.1.4.1.2620.1.6.7.5
    how do i build the components? i have tried building the syntax using macros {#SNMPINDEX}] but i keep getting errors
    thanks for the support
  • SanMonitor
    • Aug 2022
    • 49
    Hey dr.grinspoon,
    can you share some more information about the current settings you have and any errors you might get?
    I use this template for our checkpoint, maybe it's also interesting for you? Check Point monitoring and integration with Zabbix
    • dr.grinspoon
      • May 2025
      hello, thank you for your reply. I tried using the template you suggested and the CPU data is now correct. However, I can't find any data on the high reliability status of the clusters (active/standby/down).
      Also, the discovery of the vpn tunnels, provide only 10 data, seems like there is a limit somewhere.
