Performance Counter issue on Citrix VDA
  • BoBiNaTorMaStEr
    • May 2025
    Hello
    Currently deploying the zabbix agent 2 (7.0.4) on our Windows Servers across the org. Everything is running good but having some weird issue on our Citrix VDA VMs built using App Layering and provisionned using PVS.
    Basically, the zabbix agent is installed on the gold image with some variables in the configuration file making it "unique". Autoregistration is working as well, adding the VDA in the proper host group and assigning the monitoring template. The templates contains various items, mostly being performance counters (most of them are cloned from the official zabbix for windows template). Some of them are not returning any value (or errors) like CPU queue length or the % swap usage. I checked on the server itself using perfmon, I'm able to get the values. I was able to pull the same performance counter using telegraf
    on the zabbix agent logs, I can see the passive check but the result is null
    sometimes, by restarting the agent, I'm able to get some of the performance counters work, but not 100% of them (they are all working using the telegraf agent).
    I tried using the latest agent (7.2.6) with the same result
    any ideas?
    Thanks!
