V 7.2
  • vakho
    • May 2025
    V 7.2
    Hello everyone
    I am using Zabbix 6.4. I want to upgrade to a newer version, so I installed version 7.2 on another server. Now I have two Zabbixes. I am wondering if I can set one to monitor the other so that I can compare the data.
  • Brambo
    • Jul 2023
    • 250
    Yes you can.
    depending on your situation active/passive agent you need to configure the zabbix_agent conf to the second
