Problem with Telnet SSH command
  • bokaxeta
    • May 2017
    I'm having a little problem about a item Type Telnet Agent. I execute the correct comand but only works the first time that it's executed. Afterthat, in the Host where resides the Item, the item status is Not supported and the error displayd on info says:
    Cannot find prompt after command execution: [4] Interrupted system call
    I would appreciate any help, thank you!
