Actions on AWS Aurora Instances
  • fgarcia
    • May 2017
    I am new to posting on Zabbix Forums.
    My current issue is with Actions are not firing while monitoring Aurora instances in AWS. All other Actions items are working as intended.
    I started monitoring an Aurora instance in AWS. And it works, meaning I can getting data back.
    I can see the trigger fire on the Dashboard but the sections under Action is empty. I was able to test this out multiple ways. I have to create an Action item for each Aurora instance in order for the Action to be triggered. It won't work if I create an Action with "Host Group" or "Trigger Severity". I have to select a specific Host and only one host per Action. I attached some screen shots.
