What will happen to dependent triggers if i disable parent trigger.
  • sanjini
    • May 2025
    Hi All,
    I am disabling parent trigger and i see that few triggers are dependent on it. As much as i know if a trigger is disabled then it is evaluated however not shown in front-end. However I want to know will the dependent triggers be also evaluated and shown in front-end or not? Please help me with this..
  • sanjini
    • May 2025
    I am talking about a trigger regarding the interface of a switch. For an interface of a switch if i disable the trigger of the link being down . will the dependent triggers like Ethernet has changed to lower speed than it was before will this be evaluated and show up in front end? Since the item for the triggers are not disabled they are getting evaluated i am just disabling a trigger that is based on the item value.
