Automating Zabbix SAML Authentication Configuration
  • elan
    • May 2025
    I'm trying to configure SAML authentication for a Zabbix instance, but I'm running into a few challenges:
    1. There doesn't seem to be an authentication.edit API available.
    2. I haven’t found a way to push the required SAML auth attributes programmatically.
    Has anyone successfully automated this configuration? If so, I’d appreciate any guidance or workarounds you’ve used.
    Thanks in advance!
    • 4993
    Theres API method "user_directory" for that
