Multi Tenant Monitoring - Proxy Permissions
  • McRichie
    • May 2025
    I just did some test setups for multi tenancy as proposed a this zabbix blog entry: https://blog.zabbix.com/multi-tenant...oftware/12024/
    It works fine so far.
    I got a problem regarding the proxies: I seems like the proxies are global objects - so every user can see them.
    For instance a tenant admin can select/view proxies of other tenants when creating/modifying host.
    Is there any solution for this?
    regards Richard
    • 4993
    Zabbix is only half way "multi-tenant".. Or even less...
    For simple users, you can restrict, what they see, but from admin level, it falls apart..
