LLD macro name override for interface name discovery
  • troffasky
    • Jul 2008
    • 639
    I would like to be able to edit names of discovered interfaces, but you can't do that.
    Can I get LLD to create a host macro, or refer to a host macro, that I can use to override or add a label for the interface? Really only matters for the names of interface graphs.
  • troffasky
    • Jul 2008
    • 639
    This is is my first attempt. Graph prototype name:
    Interface {#IFNAME}: Network traffic {$IFLABEL:"{#IFNAME}"}
    Then created a macro on a host with that template on:
    Macro:
    {$IFLABEL:"{#vnet0}"}
    Value:
    WAN
    But not actually sure of the syntax here....so created this one as well:
    Macro:
    {$IFLABEL:"vnet0"}
    Value:
    WAN attempt 2​
    Will see if either of these work!
    • troffasky
      • Jul 2008
      • 639
      No, macro is not resolved. Graph is not mentioned here:
      so that's probably why.
      • troffasky
        • Jul 2008
        • 639
        Item-level instead, would be better than nothing. But no. Just ignored.
        • troffasky
          • Jul 2008
          • 639
          This should be working.
          Items / item prototypes
          In an item or an item prototype configuration, user macros can be used in the following fields:
          Item name yes
          • troffasky
            • Jul 2008
            • 639
            "Should" work, apparently: https://support.zabbix.com/browse/ZBXNEXT-9856
            • troffasky
              • Jul 2008
              • 639
              It *does* work! Just not when you look at the list of configured items on the host. The macro is resolved in the graph legend:
              • troffasky
                • Jul 2008
                • 639
                OK, it will resolve the macros in the graph key of the rendered graph but not the graph title of the rendered graph. It will do, for now.
