hi, fellows!
I want to get Interface Name of the interface, which was chosen as STP Root Port on certain switch (interface leading to the root switch of the net on this switch)
SNMP OID BRIDGE-MIB::dot1dStpRootPort (.1.3.6.1.2.1.17.2.7.0) returns decimal integer value as 0,1,2,3... but this decimal value does not always point to the corresponding ifname (fa0/1=1, fa0/2=2, etc)
Is there oportunity to grab SNMP value of an OID by previously taken SNMP value of an OID. I mean construction like IF-MIB::ifDescr.(BRIDGE-MIB::dot1dStpRootPort).
Here BRIDGE-MIB::dot1dStpRootPort would return decimal index of root-designated interface (let it be 1) and later IF-MIB::ifDescr.1 would return ifName
If that's impossible... can i get item of an item in zabbix? item1=BRIDGE-MIB::dot1dStpRootPort and item2=IF-MIB::ifDescr.item1
PS: I'm using zabbix 3.2 on centos7
I want to use ifName as item value, not as a name of any object
snmpwalk -v 2c -c <snmp_connunity> <switch_IP_was_here> IF-MIB::ifDescr.6 IF-MIB::ifDescr.6 = STRING: FastEthernet3/1
