Zabbix sends notification only to Admin
  • nicolacontu
    • May 2017
    I created a new media type called Slack, a new User same as Admin and a new action to send Slack notifications only to the new user if the condition for the action has matched.
    This actually does not work. If I insert also the Admin user in the Send To, it works.
    Is there any trick to make that work?
    Thanks,
  • ovas
    • Apr 2017
    • 138
    Hello nicolacontu!
    Can you please show the contents of Reports -> Action log?
    Were you using this script: https://github.com/ericoc/zabbix-slack-alertscript for Slack integration?
    • nicolacontu
      • May 2017
      Hi Ovas,
      I managed to solve the problem just loggin in with the new users.
      Thanks for your reply.
      Nicola
