How can I
  • Jhellsten
    • Jun 2025
    How can I
    ZABBIX 7.2 this question is about the template MSSQL by Zabbix agent 2. I want JUST this template to not send messages to signal.
    Is that possible? I don't want to disable triggers if that is possible. Is the only way to accomplish this to change severity?
    Thanks in advance.
    • 5002
    Sending something to signal is a matter of your action config not the template issue. I can only assume, that your action config is made to send everythign (maybe based on severity) to signal. But there are also tags in events... You could modify that action to work only based on tags... or ignore events having specific tags... Manual will help you https://www.zabbix.com/documentation...ion/conditions
    • Jhellsten
      Jhellsten commented
      Thanks for the response,
      All help is appreciated
