log time format not long enough
  • c2cannova
    • May 2016
    Log time format is 64 char long and I have a log that has 75 char long to grab the time stamp. Is there any way to get around this?
    Example:
    I add ā€˜p’ for each char that is not date & time for Zabbix time format
    | [PollableSourceRunner-JMSSource-tibSrc3] | [ ] | 2017-04-27 14:21:22
    pppppppppppppppppppppppppppppppppppppppppppppppppp ppppppyyyypMMpddphh:mm:ss
    This is what fits: 64 char total, above 75 char
    Greatly appreciate any support given.
  • ovas
    • Apr 2017
    • 138
    Hello c2cannova!
    This setting is hardcoded in two places:
    1) Zabbix web interface: <zabbix frontend>/include/views/configuration.item.edit.php, line 363, change 64 value to whatever you need.
    2) Zabbix database: items table, logtimefmt column, change varchar(64) to varchar(whatever you need).
    Try changing this for a start, though I can't predict it will not break anything else. And pay attention that updates will most probably overwrite these settings.
    • c2cannova
      • May 2016
      Thank you for your reply and support.
