Monitor API Endpoints
  • jjerpseth
    • Oct 2016
    I am fairly new to Zabbix and need help to set up monitoring of our API endpoints. All I cna seem to find is documentation on how to use the Zabbix API but I need to monitor the APIs we set up for our clients to make certain they are alive and count how many times they are being called.
  • ovas
    • Apr 2017
    • 138
    Hello jjerpseth!
    From your post it is not entirely clear, whether you want to monitor:
    1) Zabbix API instance availability and call count?
    2) Third-party API instance availability and call count?
    • WillemR
      • Oct 2015
      • 30
      i'll think you'll want to use "net.tcp.listen[port]" on the zabbix host. or you can let the zabbix server/proxy do the check with net.tcp.port[<ip>,port]
      (taken from https://www.zabbix.com/documentation...s/zabbix_agent)
