Dependent items automatically disabled by LLDP Rule
  • mattapac
    • Jun 2025
    Facing an issue which seemingly only happens with cloned templates i.e cloning the default "Windows by Zabbix agent" template.
    After cloning the template and only disabling the "Windows services discovery" rule, all devices with the cloned template will eventually have the "Mounted filesystem discovery" items disabled by an LLD rule
    When checking the template, the "Get filesystems: Mounted filesystem discovery" rule is still enabled
    This appears to only happen if I clone the original template, is there a way to understand why the dependent items are been disabled? checking the Zabbix server log file doesn't seem to have much useful information around the times the data stops collecting, and it's not one endpoint, it's all of them with said template. There is seemingly no rhyme or reason, it just stops after an indeterminate amount of time as seen in the data graphs with nothing more than ""Disabled automatically by an LLD rule", is the "Get filesystems: Mounted filesystem discovery" rule somehow reliant on the Windows services discovery" rule?
