Cascading SNMP lookups
  • cbl
    • Apr 2025
    I have SNMPINDEX_A, I need SNMPVALUE_C.
    SNMPVALUE_B is used as the Index for the next lookup SNMPINDEX_B
    So SNMPVALUE_B, needs to be used as SNMPINDEX_B. How do I do that?
    OID lookups example:
    1.3.6.1.1.{$SNMPINDEX_A} >>>> RESULT {$SNMPVALUE_B}
    1.3.6.2.2.{$SNMPINDEX_B} >>>> RESULT {$SNMPVALUE_C}
    This is being done inside an LLD, there are hundreds of these to lookup.
  • greenApples
    • Nov 2021
    This look very similar to my quest here - Using SNMP value as index to map for filtering - ZABBIX Forums. Did you ever figure this out?
