SNMP auto discovery
  • JcDuss
    • Aug 2015
    • 9
    SNMP auto discovery
    Hello Everyone,
    It's made a long time I didn't use Zabbix and I'm in testing for new releases.
    I tested Autodiscovery for snmp devices.
    My problem is , in my corp we got many snmp "read only" communities and differences per device.
    So I need to create on auto discovery rule per "community".
    Then I create the action to add it automatically in monitoring but it inherites of the standard "public" which is not working.
    I cannot figure how to personnalize the snmp community in the action menu ?
    Is it embedded or should I use a dedicated external command ?
  • JcDuss
    • Aug 2015
    • 9
    Up please
    • Semiadmin
      • Oct 2014
      • 1626
      Hy, JcDuss.
      Don't a field "SNMP community" help in discovery rule with check type SNMPv* agent"?
      • JcDuss
        • Aug 2015
        • 9
        It helps to "discover" only.
        When Discovered, you can add host to monitored host and a specific host group.
        in older version, in my memory, snmp community was defined at host level (am I wrong ?.
        I can see now in the items of templates that the community is set to {$SNMP_COMMUNITY} which is a global macro and its value is "public".
        I would have to create each template per community instead of overload the macro by host and a dedicated {$SNMP_COMMUNITY} in each host by discovery.
        So when discovered, even if a community is specified in "discovery" menu, the host will be monitored with {$SNMP_COMMUNITY} if you apply an emmebed template. :/
        Is there other way more user friendly ?
        • Semiadmin
          • Oct 2014
          • 1626
          May be, add macros {$SNMP_COMMUNITY} to the template and link this template to discovered hosts via the operation "link to template" in discovery action?
          • JcDuss
            • Aug 2015
            • 9
            Yes but it will means I will have to duplicate all basics template by the number of "community" I got
            • ovas
              • Apr 2017
              • 138
              Hello JcDuss!
              You can either add a user macro to every host for the specific SNMP Community value by hands, or run a host.update API query for the results of host.get query where you collect all the hosts that require macro to be updated.
              Cannot see easier ways here, unfortunately.
              • JcDuss
                • Aug 2015
                • 9
                Thank you for your replies SemiAdmin and Ovas.
                I'll see the API.
                And I created a feature request to make it easier from the GUI.
