How can I write this expression?
  • My_X
    • Jun 2025
    I read the value in rclone-sync-status.txt
    My expression is written like this, {S3Sync_192.168.3.122:rclone.sync.status.last()}=" failure"
    But it keeps reporting an error. How should I write this expression?
    When failure appears in my rclone-sync-status.txt file, it will alarm, and if it is success, it will recover​
    thanks
  • Brambo
    • Jul 2023
    • 256
    No knowing which version of zabbix you use is hard to guess what is correct.
    Since zabbix 6.0 trigger expresions start like last(//item...)
    You probably use a expression found by google which is related to zabbix 5 or older.
