Using user macro in http_agent item in header section (API Key)
  • freddyd
    • Dec 2023
    • 10
    How to use user macro in http_agent item in header section (API Key)?
    If I paste the clear text APIKey which was set also set in user macro before in the "X-..." Header i get the right value from the API.​
  • freddyd
    • Dec 2023
    • 10
    Has anybody an idea?
    • Markku
      • Sep 2018
      • 1784
      Are you sure that the key is correct and that the header value is in the correct syntax? (I'm not exactly sure what you meant in the copy/paste comment)
      FWIW, I'm using similar setup successfully in my items, in some of my items the header value is "Token {$APITOKEN}" as required by the API.
      Markku
