cannot connect to [[127.0.0.1]:10051
  • me2017
    • Apr 2017
    • 34
    I'm using Zabbix 3.2.6 on CentOS 7.3.1611. I see this every time I give 'systemctl restart zabbix-agent' Strangely, the host is reporting in the server's host configuration and everything seems to be functioning just fine.
    3816:20170523:111111.975 active check configuration update from [127.0.0.1:10051] started to fail (cannot connect to [[127.0.0.1]:10051]: [111] Connection refused)
    If I ask for more detail, DebugLevel=4
      3973:20170523:111638.312 __zbx_zbx_setproctitle() title:'listener #1 [waiting for connection]'
      3976:20170523:111638.795 In send_buffer() host:'127.0.0.1' port:10051 entries:0/100
      3976:20170523:111638.795 End of send_buffer():SUCCEED
    I don't see 10051 listening...
    # netstat -na | grep 10051
    And it's not defined in my config...
    # grep 10051 /etc/zabbix/zabbix_agentd.conf
    Can someone explain what's up here?
  • me2017
    • Apr 2017
    • 34
    Solved, with a stroke of genius:
    ## ServerActive=127.0.0.1
    • gonsalves2003
      • Feb 2018
      How did you resolve this? I am still struggling with the same issue.
      I have the following in my agent conf file. 192.168.25.5 is my Zabbix Server:
      EnableRemoteCommands=1
      Server=192.168.25.5
      ServerActive=192.168.25.5
      Hostname=FileServer01
      • me2017
        • Apr 2017
        • 34
        I think in my case I found simply that
        was set so I commented it out.
        I may have also had trouble with tcp wrappers. I have 127.0.0.1 included for ssh.
        I'm not sure what issue you're experiencing but since this is the server you're having trouble with also check /etc/zabbix/web/zabbix.conf.php
        Here is my servers /etc/zabbix/zabbix_agentd.conf:
        PidFile=/var/run/zabbix/zabbix_agentd.pid
        LogType=file
        LogFile=/var/log/zabbix/zabbix.log
        DebugLevel=3
        EnableRemoteCommands=0
        LogRemoteCommands=0
        Server=192.168.1.5
        ListenPort=10050
        ListenIP=192.168.1.5
        StartAgents=3
        ServerActive=192.168.1.5
        Hostname=ktlo01
        RefreshActiveChecks=120
        BufferSend=5
        BufferSize=100
        MaxLinesPerSecond=100
        Timeout=3
        AllowRoot=0
        User=zabbix
        Include=/etc/zabbix/zabbix_agentd.d
        UnsafeUserParameters=1
        LoadModulePath=/usr/lib/modules
        • gonsalves2003
          • Feb 2018
          [/CODE]
          Aah!! Mine is a windows Agent and I added all lines from your script which are relevant for Windows. In fact, here are my code:
          LogRemoteCommands=0
          Server=192.168.25.5
          ListenPort=10050
          ListenIP=192.168.25.35
          StartAgents=3
          BufferSend=5
          BufferSize=100
          Timeout=3
          The following is the error I get:
          9424:20180227:103015.423 active check configuration update from [192.168.25.5:10051] started to fail (cannot connect to [[192.168.25.5]:10051]: Connection refused.)
          I have enabled 10051 IN and 10050 OUT ports in the server. similarly 10050 IN and 10051 OUT in the client...
          • ntluan_gooner
            • Apr 2020
            i got a same problem and i hope this help
            Check your conf path:
            In my case , Zabbix agent log was:
            ....using configuration file: /etc/zabbix_agentd.conf
            So be careful !
            • ahkhan1990
              • Nov 2023
              Hello Everyone I am having the same problem . Can anyone assist me? the machines are pinging each other but agent is not working. i tried every methd in this forum and other forum but still its same. Agent is installed in Windows Server 2022 machine with the server IP and server proxy 127.0.0.1 default. I am using PSK key but still its givign me same error.
              • MRedbourne
                • Feb 2023
                • 103
                Can you telnet to the 10051 port on the proxy? Alternatively, what happens if you scan it with nmap?
                Telnet Option > telnet <Proxy IP> 10051
                nmap Option > nmap -p 10051 -Pn <Proxy IP>
                If they return closed, there's likely a firewall in the way. Can be the source, a perimeter firewall (Eg: Cisco, Fortinet, etc) or the destination host blocking the connection.
                Which version of Zabbix (Server/Proxy) are you using?
                Which OS and Version runs Zabbix Server/Proxy?
                  127.0.0.1 is localhost... if you want your agent to connect to server/proxy, put its address there instead of localhost...
                  • ahkhan1990
                    • Nov 2023
                    still the same issue .and I see that 10050 is listening but 10051 is not. and both ports are open. Zabbix server and agent machine is also pinging
                    • ahkhan1990
                      • Nov 2023
                      Hey I tried but still not working. getting the same error.
                      • ahkhan1990
                        • Nov 2023
                          Listening where? 10050 is agent port, Server/proxy connects there in case of passive agent. 10051 is trapper port on server/proxy, agent connects there in case of active agent to ask for config updates and send away collected data...
                          Make sure you can connect from agent host to server/proxy:10051 and from server/proxy to agent host:10050. If you do not succeed, find the reason, for example verify FW rules, make sure you server/proxy processes are up and running etc...
                          • ahkhan1990
                            • Nov 2023
                            failed to process an incoming connection from 10.XX.XX:XX cannot accept unencrypted connection
                              Agent?
                              Have you configured host in Zabbix GUI with all the encryption, but agent has no config?
