Log-in not possible from outside through nginx proxy manager
  • sysrq
    • Jun 2025
    I have a problem, i spent over 3 to 4 hours trying to find a solution, yet still nothing.
    I just set up Zabbix on a proxmox VM, everything works fine, i can connect and log-in with the Admin and the new password from my lan with the VM's IP /zabbix.
    The problem starts here, i tried link it to my nginx proxy manager so i can have acces from outside through my domain (as i have for all my other services). The configuration through NPM didn't work at all, i couldn't even acces the subdomain for the zabbix. Then i disabled the NPM Proxy from the dashboard and i edit the VM.conf manually. I somehow succeded to make it accesible from outside with some added lines to the config file. But now the problem is that i use the same credentials i am using to connect with my internal ip, it works, when i try to log in through that subdomain (either from my lan or from outside) i get this error:
    If you all need some extra info, just ask me. Please help me find a solution.
