Does anyone know where to find template for IBM TSM - AIX?
Template for IBM TSM - AIX
Template for IBM TSM - AIXAttached Files -
Hello HuY,
TKS for reply!
but i just to tried to import that template in my zabbix and i get this error:
"Import failed:
Invalid tag "/zabbix_export/hosts/host(1)": the tag "useip" is missing."
I think the zabbix version is incompatible.
Zabbix template version: "1.0";
My Zabbix version: "3.0".Comment
Hello!
Attached is not a template, it is host export. It is indeed exported from an older version of Zabbix server. You can:
1) Export some host from your existing server and adjust the attached XML scheme to the one from Huy. Then import should succeed.
2) Copy-paste the SNMP OID keys, there are not a lot of them really.
3) Wait/search for a proper template.
A little help for the copying process:
item type="2" - stands for Zabbix trapper items in modern Zabbixes, but in version 1 it could be SNMP
value_type="0" - stands for float type of information
All the rest is pretty much self-explanatory.
In the attached template the SNMP OIDS are the same for all the items, which is strange, but I guess possible, just didn't have the chance to use Tivoli.Comment
