How to show data rate/bandwidth in Zabbix maps?
  • skyflayx
    • Jun 2025
    I have 0 experience in Zabbix and I have no coding skills and experience whatsoever.
    I tried searching/looking using this exact question but it only leads me to posts from 2014, and there are no exact steps on how to do so so I am completely lost.
    My goal is, in Zabbix maps, to show the bandwidth on the links between our main firewall and branch firewalls. I have found that I have to create items on the firewalls first but I always get this problem.
    What should I do and how should I proceed?
    • 4996
    But it clearly says there... "no interface found" You host has no agent interface defined, but you are trying to use agent item... Define the interface and then fill item parameters with correct values (if-> your interface name, <mode> -> required mode)
    net.if.in[if,<mode>]
    Incoming traffic statistics on network interface. Integer if - network interface name (Unix); network interface full description or IPv4 address; or, if in braces, network interface GUID (Windows)
    mode - possible values:
    bytes - number of bytes (default)
    packets - number of packets
    errors - number of errors
    dropped - number of dropped packets
    overruns (fifo) - the number of FIFO buffer errors
    frame - the number of packet framing errors
    compressed - the number of compressed packets received by the device driver
    multicast - the number of multicast frames received by the device driver
