Zabbix Version: 3.0.9
I'm trying to monitor a system using SNMP. I added the OID, however when I get the data it contain a text and then the value. For example:
In zabbix, the value that I'm getting for the above item is "session-total: 0". Also, I will be setting up trigger and alert for this item. How can I discard the "session-total:" and simply keep 0 for this item? I came across few posts that mentioned the use of Regex and Macros but I'm not sure what is the best way to do this.
Can someone please help me with this?
Thanks.
# snmpwalk -v 2c -c public 192.168.1.5 netSnmpExtendMIB.4.1.2.4.105.110.102.111.11 NET-SNMP-EXTEND-MIB::netSnmpExtendMIB.4.1.2.4.105.110.102.111.11 = STRING: "session-total: 0"
Thanks.
