How to Get Only Active Zabbix Alarms via SQL (PostgreSQL)?
  • gabrielcs_dev
    • Jun 2025
    Has anyone managed to create an SQL query for PostgreSQL that returns exactly the active alarms from Zabbix, as shown in the "Incidents" tab? I'm trying to ensure that the query reflects only truly open incidents — with no duplicates, no resolved events, and correctly respecting the current state of each trigger.
    I've gotten close, but the query still returns more incidents than it should and misses some actual ones.
    Could someone please help me out?
    WITH last_items_per_trigger AS (
      SELECT DISTINCT ON (f.triggerid)
        f.triggerid,
        f.itemid
      FROM functions f
      ORDER BY f.triggerid, f.itemid
    active_problems AS (
      SELECT DISTINCT ON (p.objectid)
        p.eventid,
        p.objectid    AS triggerid,
        to_timestamp(p.clock) AS event_time,
        p.name        AS trigger_name,
        i.name        AS item_name,
        COALESCE(it.ip, '') || COALESCE(it.dns, '') AS ip_dns,
        h.name        AS host,
        p.severity
      FROM problem p
      JOIN events e ON e.eventid = p.eventid AND e.value = 1
      JOIN triggers t ON t.triggerid = p.objectid AND t.value = 1 AND t.status = 0
      JOIN last_items_per_trigger f ON f.triggerid = t.triggerid
      JOIN items i ON i.itemid = f.itemid
      JOIN hosts h ON h.hostid = i.hostid AND h.status = 0 AND h.maintenance_status = 0
      LEFT JOIN interface it ON it.hostid = h.hostid
      WHERE
        p.r_eventid IS NULL
        AND p.object = 0
      ORDER BY p.objectid, p.clock DESC
    SELECT
      ROW_NUMBER() OVER (ORDER BY event_time DESC) AS incidente_n,
      ap.host,
      ap.trigger_name,
      ap.item_name,
      ap.ip_dns,
      ap.event_time,
      CASE ap.severity
        WHEN 0 THEN 'Not classified'
        WHEN 1 THEN 'Information'
        WHEN 2 THEN 'Warning'
        WHEN 3 THEN 'Average'
        WHEN 4 THEN 'High'
        WHEN 5 THEN 'Disaster'
      END AS severidade,
      CONCAT(
        DATE_PART('day', NOW() - ap.event_time)::int, 'd ',
        (DATE_PART('hour', NOW() - ap.event_time)::int % 24)::int, 'h ',
        (DATE_PART('minute', NOW() - ap.event_time)::int % 60)::int, 'm'
      ) AS duracao,
      STRING_AGG(pt.tag || ': ' || pt.value, ', ') AS tags
    FROM active_problems ap
    LEFT JOIN problem_tag pt ON pt.eventid = ap.eventid
    GROUP BY
      ap.host, ap.trigger_name, ap.item_name, ap.ip_dns, ap.event_time, ap.severity
    LIMIT 1001;​
  • gabrielcs_dev
    • Jun 2025
    I was able to resolve the issue.
    SELECT
        ROW_NUMBER() OVER (ORDER BY TO_TIMESTAMP(p.clock) DESC) AS "Linha",
        TO_CHAR(TO_TIMESTAMP(p.clock), 'YYYY-MM-DD HH24:MI:SS') AS "Horario",
        CASE
            WHEN p.severity = 0 THEN 'Not classified'
            WHEN p.severity = 1 THEN 'Information'
            WHEN p.severity = 2 THEN 'Warning'
            WHEN p.severity = 3 THEN 'Average'
            WHEN p.severity = 4 THEN 'High'
            WHEN p.severity = 5 THEN 'Disaster'
            ELSE 'Unknown'
        END AS "Severidade",
        p.name AS "Problema",
        FLOOR(EXTRACT(DAY FROM NOW() - TO_TIMESTAMP(p.clock))) || 'd ' ||
        MOD(EXTRACT(HOUR FROM NOW() - TO_TIMESTAMP(p.clock)), 24) || 'h ' ||
        MOD(EXTRACT(MINUTE FROM NOW() - TO_TIMESTAMP(p.clock)), 60) || 'm' AS "Duracao",
        h.host AS "Host",
        it.ip || it.dns AS "IP"
    FROM problem p
    INNER JOIN (
        SELECT MAX(itemid) AS itemid, triggerid
        FROM functions
        GROUP BY triggerid
    ) f ON p.objectid = f.triggerid
    INNER JOIN items i ON f.itemid = i.itemid
    INNER JOIN hosts h ON i.hostid = h.hostid
    LEFT JOIN interface it ON it.interfaceid = i.interfaceid
    INNER JOIN triggers t ON f.triggerid = t.triggerid
    -- Join correto com a tabela 'events'
    INNER JOIN events e ON e.eventid = p.eventid
    -- Exclusão de suprimidos
    LEFT JOIN event_suppress es ON es.eventid = e.eventid
    WHERE
        t.value = 1
        AND t.status = 0
        AND p.r_clock = 0
        AND i.status = 0
        AND h.status = 0
        AND es.eventid IS NULL  -- ❌ exclui problemas suprimidos
    ORDER BY "Horario" DESC;
